bswaminathan
HiThanks for the reply. your response is really meaningful and has shed a new light. as per you, if i connect the cable TV wire then it will simply pass it to the TV. can i scroll the cable channels with the STB remote? pls check it once, if the STb remote can't command over the channel then there is no use in using the STB. Thanks again. if you connect cable Tv wire and also your DTH then how do you select the source, if you choose cable TV then how do u scroll the channel. because there is an option for antennae input where terrestial antennae in general gets more than a channel, in that case there should be a way to get them where are you put up, if in tamilnadu pls give your contact no, I keep the plan of buying TV in mind, even if i buy a TV i will migrate to FTA DTH since most of the private channels are available in FTA DTH. Thanks allI not only use the STB as tuner/remote feature but in future i might include DTH and is likely to happen, that's why I'm clubbing. lets see....
