Connection Stops Working After 9/10 Hours
  • Thread starter Thread starter trump
  • Replies Replies 7
  • Views Views 2,463
trump
trump
airtel
connection stops working after 9/10 hoursdetails=modem=beetel 220bxtype=pppoewhen the connection drops all the lights on the modem are on[no flashing].modem page [192.168.1.1]also doesnt open and no other website opensthen-turning modem off/on it starts working againi tried searching forum but no previous post solved this problemcan anybody suggest what the problem could be?
QUOTE(trump @ Jan 15 2007, 03:44 PM) [snapback]75239[/snapback]
details=
modem=beetel 220bx
type=pppoe
can anybody suggest what the problem could be?[/b]
dude i'm also havin the problem, found one solution which works in 90% of times....
Solution - As soon as you connect via pppoea... go to network properties, right click on the 220BX modem - and click repair...... and u r done....
need to do this whenever you restart the comp...
i hope this might help you....
do post after tryin the solution.....
will try it when problem occursbecause i did not usedpc yesterday for long timethx for solution [if it works]
Try running it in bridging mode and create a dialer, select idle time before hanging up as never....Your problem should be fixed :)
