@infernalproteus
Firefox
ws; U; Windows NT 5.1; en-US; rv:1.9.1) Gecko/20090624 Firefox/3.5
http://img27.imageshack.us/i/datafoxsettings.jpg/
User name and password not saved.
In about:config entries were seen in earlier FF versions. .
Datafox no longer seems to work on BSNL. Any idea how can i make it to work?
working fine for me for bsnl dataone IP 59.xx.xx.xx
If your IP is 117.xx.xx.xx
select only
BSNL - Broadband Account Management
usage portal site BSNL Portal
needs additional input like account no ,etc to show usage.
Try in FireFox browser as an add On. Present version 1.7.5
Type in FireFox addrress bar about:config
read the warning!
scroll down for Datafox entries.
Post screenshot.
compare with screenshot given below.
http://img27.imageshack.us/img27/8266/datafoxsettings.th.jpg
select only
read the warning!
Post screenshot.
I have bsnl dataone IP 59.xx.xx.xx and have also update to version 1.7.5. However, it still does not work.
Screenshot posted is to small to read.
Here is my screenshot:
http://i28.tinypic.com/20subna.jpg
PS- this problem started after I updated to FireFox 3.5
^ http://img27.imageshack.us/img27/8266/datafoxsettings.jpg
did you try changing the domain address in datafox & what is your ip range ?
What error message do you see when you hover over the DataFox icon?Also, have you chosen to override the domain DataFox uses to check data? If so, what domain are you using? Try using another one - 10.240.240.195 seems to be working for me.
@infernalproteus
Now I am on Airtel ISP.
Cannot ceck ip 59.xx.xx.xx
But could log in with ID PW for 117.xx.xx.xx
at BSNL - Broadband Account Management
Tese additional entries appear in about :config
ID and password seems to have been saved.
datafox.active.domain;bbservice.bsnl.in
datafox.active.user; xxxxxxxxxxxxxxx
datafox.save.password;true
PROBLEM:
I found my UserID and PW not saved.
when logged in BSNL ISP> dataone.
please see screensot in Post No.359
Usage/ access to Dataone portal pretty fast as usual.
PS: Sorry. KBD trouble. Have to bang "H" key !
I had not chosen to override the domain DataFox uses to check data. Thanks a lot. Its working perfectly now.
Post 365Now OK. ID and password saved.datafox.active.domain;10.240.89.199datafox.active.user;essbebedatafox.save.password;true
