DataFox for chrome :)
Been almost ready for a month! Finally pushed it out. BSNL support only - but not support yet for selfcare/Hyderabad users. Give it a spin and let me know!
Congrats. Will try it.
@ BrianI am using ULF 1100. Is there any method for me to see how much FUP data is remaining. If you can add it, it will be a great boon. Most of ULF users depend on the bandwidth meter for this purpose. I have seen usage data diagram. If it can set to FUP also (in BSNL site, chargeable units will be zero), it will be nice.
my datafox is giving login error. i can login to 10.240.144.195 url, and can see my data ushage but i cant login in BSNL Portal
If you can log in at 10.240.144.195 and DataFox gives you usage report, from same menu you can access the Portal for detailed usage data.
Your Ip should be 59.xx.xx.xx with user ID abcd @dataone.in
BSNL Portal is for users with abcd @ bsnl.in and Ip 117.xx.xx.xx
i go to the website10.240.144.195 and then login with username and password to see my usage. but when i put the same in datafox login with domain=10.240.144.195 it gives me error loggin in, please check your username, password & domain
Try :check " override default settings " box
or any othewr IP in the list.
Update FireFox version.
---------- Post added at 05:12 PM ---------- Previous post was at 05:11 PM ----------
or any other IP in the list.
i have done it all but no use. i still have the same problem. and also i have told by the bsnl that my new website for seeing usage is 10.241.96.195. i have also put in the above url in datafox but result in same error. i have the latest firefox and datafox version
firefox ver= 3.5.9
datafox ver= 1.9
my os is linux ubuntu 9.10 Karmic Koala
