@BrianOh! This is really very cool extension.You are making life lot easier my friend. :D I really mean it, a thousand kudos to you. :wub: :wub: :wub: :wub:
@ Brian
could you please respond to the following problem ... thanks
https://broadband.forum/showpost.php?p=78822&postcount=3
i installed datafox plugin. but its not working properly. it shows error.
is this because i dont use the direct bsnl path but an ip ( 10.0.0.45:8080)
to check my usage? i typed that in the ip box. still it doesnt work?? help me out
Hey Guys,Thanks for the compliments :) For all those waiting for the next version, I want to say that I am working on DataFox whenever I get time, but I am going through a particularly busy phase at work which would probably last another couple of weeks at least, hence the delay :(The next version is going to be worth waiting for :)Stay tuned,Brian.
^ @subham , Datafox should be compatible with your version of firefox .
actually it should work up to firefox 3.x . anyway , at present pls use
MR Tech Local Install extension to make Datafox compatible with your firefox .
I just noticed this post so I haven't looked into this yet - any one else seeing these issues after upgrading to 2.0.0.4?Brian.
