TRY option 4 first.
Option 1
.Start
Network Lan connection
Properties
Network settings
TCP/IP
properties
See the page.
Default gateway is shown.
Option 2
Still problem accessing 192.168.1.X ( usually 1)
select Obtain Ip address automatically.
Apply Save
Option 3 :
Again
Start RUn type cmd OK
New window
type
ipconfig /all
Check the default gateway.
Try again
Option 4 :
Still problem
If you are connected to Internet
Check
Current IP Check
Type this address in address bar
Do you get the modem log in page ?
Option 5:
Still problem
If confident of re entering all values in modem
RESET the modem to Factory settings by
pressing the RESET button in the back for
about 30 seconds with Power on to the modem.
Try again.
still problem
Option 6:
Depends on feedback !
192.168.1.1 admin PWadmin or utstar
Feedback for each step tried.
