^ Great, thanks One more question. Does that also mean that if I have to go for speeds higher than what is mentioned there, let's say 8 Mbps, I will require a change in equipment?
no you dont need to buy anything else.. if you choose an 8mbps plan , airtel would automatically sync you to 8mbps , then the line rate would show 8mbps..
I've got the same problems as the OP, but mine started after I changed my router to a D-Link after my first Billion router got fried in a lightning storm. It seems the dlink can't handle heavy torrenting....
