Dish TV introduces DTH portability
  • Thread starter Thread starter rahul10
  • Replies Replies 21
  • Views Views 12,171
actually there are 59 channels by DD which are at 0 of cost to both Dish tv & customers but dish tv doesnt offer those free & remain channels they charge Rs. 450 / 12 months where you do not need to subscribe any pack & can enjoy 95 channels free.
I give you a trick.
You are existing subscriber of Dish TV just go to menu > STB > press read button > LNB Setting > Change hi 10600 to 9700 & you can enjoy DD Direct plus for free.
Warning:
Change above parameters before Dish tv lock your box subscription. U can say before within 1 hour / any day of expire subscription.
If you to recharge again & watch pay channels by subscription, change parameters 9750 to 10600 & recharge. but if dont want to recharge & you change the parameters like that dish tv lock stb while you dont recharge again.
@ xmen
There is much important thing is check what picture quality dth box you have because see this order Advanced - older.
DVB- s2 > MPEG 4 > MPEG 2
DVB - S2 can play all previous formats (MPEG -4 & MEPG -2)
MPEG - 4 can play MEPG - 2 but cant DVB - s2
MEPG 2 cant play any other format except MPEG - 2
You need to check which dth picture type you have of your dth box.
D2H & Airtel = DVB - S2
Big TV(Medioguard Cam) & Sun direct (Irdeto Cam) = MPEG - 4
DIsh (Conax Cam) & tata (Videoguard Cam) = MPEG - 2
I dont know you know this / not but I think you know this. By the way I give information about this.
@ pkarthik
I think they will allow their customers to subscribe dish tv true packs monthly. I think you contact to cc & clear the matter & post the result here. I dont know more than this but confirm it plz.
Yeah I am aware of the dvb-s,s2 and the different compressions. I wanted to know if this cam is interchangeable when it comes to different smartcards... found out its not through you. By the way checked my d2h STB and indeed there is a CI slot above the smartcard slot which should accept the cams.But switching to dishtv is a whole different ball game altogether :P
@ xmenIf you are bothered by D2H picture quality its really good hope for us that Dish tv launched Cam in market & it great news & work buy Dish TV, Isnt it? & you mentioned game word in above message. Thanks. I forgot to mentio n there that few active services will not work properly with cam like game & other direction key basis services according to me. Be happy now & change :P to :).Compliment is to you that good ratio you have about get likes.@ IMThanks buddy. I hope who suffering from D2H's bad picture quality (I think you are not but I think mostly of SD D2H viewers) they have good option now by Dish tv because dish tv is best than D2H for manys.
^ dude I am not suffering from d2h picture quality on the other hand I am very much satisfied with it. I am happy seeing interoperability coming into place. :)
Is there anyway I can move from DishTV to Reliance Big TV and wht all i have 2 do?
Presently in India we dont have STB Portability.... You have to wait some more months to get that.... if your sure to get rid of Dish TV then buy the Reliance as a new subscriber...
Thanx mate but then i have to get all the things such as setup box and antenna frm reliance right or will my exiting dishtv setup box n antenna will work?
@lihkinYou have to buy STB & DISH From Reliance but you can keep your existing cable line, reliance cable you keep it as spare.... ---------------Can anybody clarify this dishes is common for all Operators... or each direction operators separate dish?
Look
If you talking about access RDTV on Dish TV it is not possible. Dish TV has MEPG - 2 & RDTV has MPEG - 4. So dish tv cant shows video from RDTV but u can listen just audio from RDTV, no video.
You need Mediaguard CAM (my guess) to access RDTV DTH through an MEPG - 4 / above of it technology FTA receiver included CAM feature.
I tried for buying a viewing from RDTV by mail them but they just sent me their existing entry offer links. If you too want buy a RDTV viewing card then mail to their cc & also send the mail adding TRAI emails.
Good way is direct buy RDTV.
If u use portability you cant use few interactive services from RDTV properly. It happens & adviced by experts. You need to redirect your dish to RDTV dish way.
