DMZ problem in UTSTAR R300R2U...!!!!
completed.69
BSNL
Hey guys i'm a newbie to this forum:yahoo:...!!!
I'm using BSNL H500C+ 2mbps connection since an year...!!!
i was not aware of port forwarding till last month and gone thru all the posts in this forum and decided to use DMZ ...!!! till last week everything was working fine n utorrent was showing green icon , i daily activate my DMZ at 2 AM IST n deactivate it at 8 AM..!!!
but since last week when i activate DMZ n use utorrent it shows green icon n says port is forwarded but after some time maybe an hour or something the icon turns yellow(triangle with an exclamatory mark)itself and says port is not forwarded and i can see the changes in my dl speed...!!!! In green icon i was able to dl in 200 KB/s. but in yellow i can hit a max of 120 KB/s:cry:...!!! so the problem is though i activate DMZ, after some time the port gets blocked...!!!:confused:(just getting this from last week)
hope u guys solve it..!!!!:thumb:
Details:
BSNL H500C+ with 2 mbps
UTSTAR R300R2U
DMZ activated through 192.168.1.2 ( i use Ethernet port)
utorrent 1.8
windows 7 RC build 7100..!!!
if you are on Dialer mode all ports are open.
Whether you activate DMZ or not is not important.
Please explain how you do it daily.
