doing a little survey thing
  • Thread starter Thread starter makubex
  • Replies Replies 5
  • Views Views 2,004
makubex
BSNL
Hi guys
I'd like to ask you all one little favour.
Anyone who has a BSNL connection (256K), please do a tracert on the ip 69.89.80.60, and post your results here, please do this test during the evenings.
Its the ip of the server of an MMO i play, I get lots of lag, and BSNL say everything is fine on their side. (like hell it is!)
To do a trace go to the DOS prompt (Start > Run > type in "cmd" without quotes > hit Enter)
once inside, type in tracert 69.89.80.60 >trace.txt, this will save your tracert details onto a file (trace.txt), the file will be located in C:\Documents and Settings\
Post your results here (screenshots or txt),
This is my tracert report:
Code:
5   945 ms   952 ms   940 ms  125.17.12.9    6   950 ms   946 ms   961 ms  125.21.167.29    7   929 ms   934 ms   950 ms  203.208.192.165    8   950 ms   958 ms   944 ms  ge-0-0-0-0.sngc3-dr1.ix.singtel.com [203.208.149.77]    9   395 ms   401 ms   912 ms  xe-1-0-0-0.sngc3-cr2.ix.singtel.com [203.208.183.37]   10   970 ms   956 ms   947 ms  so-5-0-0-0.laxow-cr2.ix.singtel.com [203.208.172.102]   11   468 ms   940 ms   421 ms  ge-0-1-1-0.laxow-dr2.ix.singtel.com [203.208.171.22]   12   948 ms   925 ms   956 ms  net2ez.any2ix.crgwest.com [206.223.143.38]   13   394 ms   392 ms   402 ms  lax4-pr01-1-8-to-lax4-br02-1-1.net2ez.com [64.93.64.89]   14   860 ms   915 ms   930 ms  64.93.64.110   15   984 ms  1044 ms   931 ms  lax4-cas01-1-1-to-lax4-cr01-7-1.net2ez.com [64.93.64.14]   16     *        *        *     Request timed out.  17     *        *        *     Request timed out.  18     *        *        *     Request timed out.  19     *        *        *     Request timed out.  20     *        *        *     Request timed out.  21     *        *        *     Request timed out.  22     *        *        *     Request timed out.  23     *        *        *     Request timed out.  24     *        *        *     Request timed out.  25     *        *        *     Request timed out.  26     *        *        *     Request timed out.  27     *        *        *     Request timed out.  28     *        *        *     Request timed out.  29     *        *        *     Request timed out.  30     *        *        *     Request timed out.   Trace complete.
As you can all see I'm rerouted to some Singaporean server, I tried a tracert to that same ip at my university, there the ping times are much less! They dont have to go through that Singaporean servers.
My uni has a BSNL leased line, what pisses me off is BSNL discriminate between leased line and DSL users.
DSL users always get crappy service.:madness::@
EDIT: tracert at university:
Code:
Tracing route to 69.89.80.60 over a maximum of 30 hops   1
your ping going more than 700 ms ..are they on satellite ?..what was the latency before ?.. may be they are on somr kind of backup link.call customer care.pls post tracert for some common servers say google, broadbandforum.co etc.Mine going through teleglobe ( BSNL advertised there routes throuhg teleglobe ?..) :confused:This host is down ..no services running at all 8 289 ms 288 ms 288 ms if-1-3.core3.PDI-PaloAlto.Teleglobe.net [207.45.213.153] 9 290 ms 306 ms 290 ms if-1-1.mcore4.PDI-PaloAlto.Teleglobe.net [207.45.196.78] 10 293 ms 299 ms 330 ms if-4-0.mcore4.LAA-LosAngeles.teleglobe.net [216.6.86.10] 11 293 ms 297 ms 294 ms if-0-0-0-725.mcore3.LAA-LosAngeles.teleglobe.net [216.6.84.69] 12 298 ms 292 ms 294 ms if-6-0.core1.LXE-LosAngeles.teleglobe.net [216.6.84.6] 13 985 ms 996 ms 985 ms ix-3-2-907.core1.LXE-LosAngeles.teleglobe.net [64.86.173.130] 14 1001 ms 979 ms 973 ms 64.93.64.110 15 937 ms 945 ms 952 ms lax4-cas01-1-1-to-lax4-cr01-7-1.net2ez.com [64.93.64.14] 16 * * * Request timed out.
here's my tracert report for broadbandforum.co: 5 239 ms 239 ms 239 ms 125.16.156.17 6 305 ms 312 ms 337 ms 125.21.167.74 7 264 ms 265 ms 306 ms 203.208.190.177 8 254 ms 255 ms 256 ms ge-0-1-0-0.sngtp-dr1.ix.singtel.com [203.208.149.158] 9 324 ms 325 ms 364 ms ge-1-0-0-0.sngc3-dr1.ix.singtel.com [203.208.173.134] 10 253 ms 271 ms 253 ms xe-1-0-0-0.sngc3-cr2.ix.singtel.com [203.208.183.37] 11 280 ms 254 ms 272 ms ge-0-0-0-0.sngc3-ar2.ix.singtel.com [203.208.172.166] 12 293 ms 288 ms 288 ms 203.208.191.22 13 450 ms 447 ms 439 ms 203.211.159.21 14 455 ms 458 ms 450 ms 34.203-211-159.unknown.qala.com.sg [203.211.159.34] 15 465 ms 459 ms * 171.210-193-49.idc-colo.qala.com.sg [210.193.49.171] 16 449 ms 468 ms 463 ms 171.210-193-49.idc-colo.qala.com.sg [210.193.49.171] Trace complete.for some reason those singtel servers seem to be the problem. I should be going through teleglobe too, I never had this kinda lag before, not even during peak times.
This is not about the routes taken from teleglobe or from singtel ( This depends on preferred routes for the particular host (configured for BGP, AS-AS ). I am concern with high latency only ...900 ms !!
whatever the problem is, BSNL have no idea that there's a problem. I know for a fact that such kind of ping times are just not right. This problem is recent, before I had ping times of ~250-280 ms & I'm pretty sure I was not routed through the singtel servers.
