DSL LED continuosly blinks
  • Thread starter Thread starter akgiri2005
  • Replies Replies 6
  • Views Views 4,826
akgiri2005
BSNL
I have recently subscribed for the BSNL Broadband. The modem ZXDSL AII and its related drivers have been loaded by a contractor hired by BSNL. But the DSL LED continuosly blinks where as, as per the contractor, it should glow continuosly for establishing the internet connection. The contractor has told that the installation id ok and there is some problem with the line. But the lineman from the BSNL, tells that the line is ok. I think the BSNL personnels, don't want to do any extra effort, to find out the exact problem. I also feel no audible disturbance while usung the phone line. Can anyone tell me that whether the line is faulty or the modem/installation may be faulty. Regards
Welcome to Broadbandforum.inCheck this Telephone Box ===>Rj11===>.splitter==>>Adsl Port ===>>RJ11==>to modem. .........................................................>>PHONE====Rj11 to ALL phones.Remove any other telephone/cordlessbase connected direct from the Telephone Junction box.Did the Internet connection work at least for a minute or 5 minutes ? Did the contractor enter settings in your computer ?
Thanx essbebe, for your quick response. I have removed all the parallel connections and tried but could not succeed. What settings are to be entered in the computer? The contractor has loaded the driver, I thought this was enough. Please let me know what type of setting he has to do, so that I can check it and if not done ask him to do. Thanks again for your response.
@ramblr2006 do you have /use ZTE zxdsl 831AII modem ?
please guide @akgiri.
@akgiri
Test : Start run type cmd type ipconfig/all
you should get 192.168.1.3
subnet 255.255.255.0
Default Gateway 192.168.1.1
( the contractor must have loaded some drivers for USB connection )
for always on connection.
1.Try this for your modem.
Open IE in address bar type 192.168.1.1 Id admin Password admin
( will check again )
In the WAN page
Select VPI VCI as 0 and 35 for Datone.
Select PPP/PPPoE or similar.
Enter your Bsnl ID without @ bsnl.in
Enter Password
Select ALWAYS ON.
ENABLE DHCP GIVE RANGE 192.168.1.3. to 192.168.1.40
Save reboot. Wait for two or three minutes.
In computer : Start
Network/Local area connection/ properties/TCP/Ip properties
select assign Ip address automatically.
Enter DNS 208.67.220.220 and 208.67.222.222
Report progress. Light blinks because there is no connection to the server at BSNL.
Also see
https://broadband.forum/bsnl-dataon...-configration/ (Zte Zxdsl 831aii Modem Configration)
i had an unstable dataone connection initially. i had called their support number and they had asked for the readings of some parameters, which i gave by connecting to the DSL modem. they said one of these parameters is very low (i forget which one) and they would inform the exchange. i'm not aware of what transpired after that, but after a few days the link became very stable and has been that way ever since. of course i'm in bangalore, so the quality of their support may be better here.... if you wish i can let you know the values of those link related parameters i see on my modem and you can compare it with yours....
Dear Essbebe, thanks for giving the details. I got checked my telephone line. Although the lineman says that there was no problem in the line, the internet connection on BSNL broadband connection is working since yesterday, just the speed is bit slow.. Your information and setting details will help me in future also. Thanks again.
Thanks. Try this program for speed. Just select program's default values..
You need not change anything.
trackzapper.com/booster.htm ( add www.)
Note down the present settings of modem in a notebook. ( for future reference)
