From yesterday I was noticing slowdown in speedtest results, the speed seems to be around 50 Mbps download but the upload speed is not affected, but connecting the wire from my router to PC solved the speedtest speed problem (95 Mbps up and down), but once I connected the wire to my mobile using otg ethernet adaptor, again the same issue, even AC WiFi was giving same 50 Mbps speed.
long story short, the only way to get full speed is using a windows based computer using ethernet (connecting WiFi to laptop gives even lower 20-30 Mbps speed even though my laptop's WiFi can easily achieve 100 Mbps speed), I tried 2 router and same problem.
It seems windows fixes the problem but same is not the case with Linux devices.
