For weeks its was the cable cut but I guess that must be fixed now but since last 2-3 days, the speeds are totally a joke. I can't even get a 5 MB file of RS or anywhere. In in Home 500 plan and other details are below
Device Info
Board ID: 96338L-2M-8M Software Version: 3.08.BSNL_02.01.02_tr64. Bootloader (CFE) Version: 1.0.37-8.7 Firmware Version: UT300R2U.0011.01 Hardware Version: UT300R2U 2.2 Model Name: UT300R2U Statistics -- ADSL
Mode: G.DMT Type: Fast Line Coding: Trellis On Status: No Defect Link Power State: L0 Downstream Upstream SNR Margin (dB): 29.2 25.0 Attenuation (dB): 9.0 0.0 Output Power (dBm): 7.7 9.6 Attainable Rate (Kbps): 8480 1160 Rate (Kbps): 2048 512 K (number of bytes in DMT frame): 65 17 R (number of check bytes in RS code word): 0 0 S (RS code word size in DMT frame): 1 1 D (interleaver depth): 1 1 Delay (msec): 0 0 Super Frames: 133634 133632 Super Frame Errors: 0 0 RS Words: 0 0 RS Correctable Errors: 0 0 RS Uncorrectable Errors: 0 N/A HEC Errors: 0 0 OCD Errors: 0 0 LCD Errors: 0 0 Total Cells: 10973276 0 Data Cells: 213330 0 Bit Errors: 0 0 Total ES: 0 0 Total SES: 0 0 Total UAS: 12 0
I am using PPoE in always on mode on a Vista laptop. FF 3 is my browser. Not sure what else to post to help the experts here judge the problem. So please let me know whatever else you need to know.
Device Info
