Extension cable for broadband modem
  • Thread starter Thread starter ItsMe
  • Replies Replies 2
  • Views Views 3,096
ItsMe
Its Me only.
ADL
Hi All, Im using the network port of my cable modem with my desktop and the USB port with my laptop. (I cant use them simultaneously). Since my modem is near my desktop, can I extend the USB cable (maybe using an extension cable of say 10m) to the next room so that I can use my laptop conveniently ?I have only seen USB extension cable of upto 3m. Is there any longer cables available? Will that work or will it affect the speed? I am not planning for a wireless cable modem, coz it is costing me more than 4k. Any USB bluetooth extension device available? Your suggestions are most welcome.
Better to use modem LAN Port==>> longer Rj45 cable ====>>> laptop.Connect Desktop to USB port. ( data transfer slower )USB 2.0faster. Mention Cable modem model number and service provider. ADL ?
Thanks @essbebe, I was also thinking in the same lines. Earlier my dektop was not responding to the USB port of the modem. Will check it out again and report.Yes service provider is ADL. Need to check the model no: , I think its a motorola modem.
