Getting less than 50mbps on my 300mbps connection
  • Thread starter Thread starter Elsa
  • Replies Replies 43
  • Views Views 5,329
Mumbai
BSNL
Hello Guys,
Recently like last night I joined BSNL Fibre in Bhubaneswar, However to my dismay I have been getting only 20-30mbps on a connection of 300mbps even on 5ghz band.
Kindly advise what can be done? The equipment I am using are
Modem- Netlink GPON ONT 2GE+1POTS+ac WIFI (HG323DAC)
Router- TP-Link Archer C6.
Almost all the devices on the setup are Macs and they lack ethernet ports.
I called up the vendor and he told me that I need to speak to bsnl fibre people directly and that they'd be able to help me, and to utilise a 300mbps connections certain more changes need to be done otherwise I'll only be able to use 100mbps. Pls advise and help me in this situation
Solution
Tldr: BSNL vendors in Bhubaneswar don’t like investing in quality OLT and sell oversaturated ports. So avoid BSNL fibre. Same is the case with direct Bsnl as well but you can complain on PG portal. But if you complain on PG portal against vendor. BSNL people save the vendors ass. Kudos to @Xposed for helping out of his way.
So I’m filling a consumer complaint against BSNL and vendor. Wish me luck :)
@vasudha I am with jio as Airtel isn't available
Still paying BSNL to keep my number active
Please look for the nearest location where jio is feasible , call the sales guy and tell you will pay extra if he can provide you with a connection bribe him 1k
When it comes to jio , sales can do wonders top it up with 1k bribe and viola! You have a connection
Which area are you exactly ( dm me the full address) , I will see if I can pull some strings to make it happen for you
@Xposed don't have the DM option available/enabled. Any other way to reach out. This is my first post on the forum 😓 I don’t mind even 2k as a bribe for Jio to access high speeds. You know I’ll get him even a few more houses in my locality lol. I stay in Old town area. Beside.
i am from oldtown too and i am having same problem i have take 100mbps plan but the speed is fluctuating between 60 to 70 mbps any solution ?
Yeah and ensure you are checking on wired connection not WiFi which can be unreliable.
I checked with ethernet wire its 100Mbps plan but with ethernet i am getting different Speed from different websites from fast.com i am getting 90Mbps and from google speed test 50-60 and ookle 50-60
