Getting slow speed on unlimited combo 550 plan - DSL_Unltd_Combo_550
  • Thread starter Thread starter AKS020
  • Replies Replies 3
  • Views Views 1,796
AKS020
none
it is showing
Downstream Upstream
SNR Margin​
19.8 20.2 db
Line Attenuation​
50.0 29.1 db
Data Rate​
643 508 kbps
Attainable Rate​
3560 996 kbps
POWER​
0.0 3.3 dbm
CRC​
6 65504
Item Downstream Upstream Unit SNR Margin 16.5db 17.0db dB Line Attenuation 26.0db 16.0db dB
Same plan I am getting speed as advertised - Download 1 mbps day and 1.5 mbps night, upload around 0.5mbps
How much you are getting? Line attenuation seems very high for you.
Line attenuation oes to 53 also for me many times.
also the SNR Margin comes to even 3 then also connection is giving ok speed .
but now SNR Margin is 10 .line man tells everything is ok and to change the telephone wire which is very difficult as it is concel wiring not wiring from outside .
