Going wireless
  • Thread starter Thread starter netant
  • Replies Replies 21
  • Views Views 10,576
netant
۩ ŚŧäГЏЅ ΞПЖ
Somewhere
Hello guys, im back after a long break :) with a plan to go wireless. consider me n00b in wireless thingi & I expect the experts to guide me in right direction (yes i searched the forum for similar post but unable to find exact conclusion) so here i go.......... :thumbsup:Currently im using my bsnl DataOne connection on my XP based Desktop via dial-up connection for PPoE (no setting done in the beetel modem) plugged in my LAN card. Now i planning to go wireless so that i can use the connection on my lappy & wi-fi enabled phone (soon going to get iPhone too :yahoo:)My lappy Dell XPS1730 has vista home 32bit on it.How should i proceed, which hardware i need? is the ADSL Wireless Router is enough (what exactly is ADSL Wireless Router)?please suggest me a economic way to go wireless ( should be stable) will i able to share my files between the lappy & desktop in that wireless network?and the biggest question who is gonna come to my home & set-it-up :P,i mean how can i set up the things after getting the hardware.now..... please shoot ur suggestion !!
debashish said:
Hello guys,
Good
If you have an ADSL Wireless Router, you can even avoid the Beetel Modem. You can just connect the Telephone cable directly to the ADSL Router and use as Modem+ Router !
If you just buy a Wireless Router, you can connect your modem + Router and use the wireless
ADSL Wireless Router is enough for your setup ! (unless you want to connect Desktop also into Wireless. If you want to connect Desktop, you need to buy PCI/USB wireless adapter for Desktop)
Get an ADSL Wireless Router and install for yourself
Stable ? Unless you go far away from wireless (more than 100ft idealy)
Why not ? But transfer will be slower compared to wired network ! 54mbps and 100mbps (less speed is only between computers only, not much on internet)
You can do it yourself when you have such a wonderful forum like this !
debashish said:
Hello guys,
Good
now.....
i did !
Thanks appus!
Thanks essbebe!
actually big thanks to appus :), for such a step by step answer.
so from above replies i think the only hardware i need is the ADSL Router for connecting multiple devices.
i goggled 2 router Netgear DG834G & Linksys WAG200, can someone suggest me which is best (i won't go for the bsnl tin-box:wall:), will i be able to receive the signals in the ground floor when the router will be placed on 5th floor, not to crowed surroundings)
is it possible to keep my connection in dial-up mode? which can be dialed form the workstation or the lappy.
here i drawn a estimated data-flow chart im expecting from the setup.
http://img224.imageshack.us/my.php?image=networkgraphdp1.jpg
5th floor ? Not Sure, you may get distance, but... quality of signal has to be checked ! Go to a Computer market for checking router. You will get for less than 3000 ! And, why this dialing ? Let that be connected always right ? You can set the idle time on disconnect (if at all you want to disconnect) in router ! When some PC trigger internet activity, it can get connected ! Normally password/userid is stored in router !edit : you can connect all the devices in your image !
im not on unlimited plan, so i feel it to be more safer on dial-up mode.
their might be a case that the signal is being received by my neighbors, & you know 1Hr = Rs. 800.
& i faced a lot of disconnection in in always on mode, see the link in my signature for the details.
nice :thumbsup:
:thumbsup:
Once you secure your wireless with encryption, it is hard to break the wireless network and use it ! You can identify if there is any clients are accessing other than the permitted ones in your router !
Guys,
finally i got Linksys WAG-200G (ADSL home Gateway) cost me around 3300/-.
Setting it up is damn easy, as it has a wizard in the installation disk which sets the BSNL connection very easily with few clicks.
By the time im configuring the Home network connection between my computers.
i just like to know is it possible to use PPPOE dial up mode rather then just always on mode.
if possible, what would be the ideal setting in the modem/gateway.
i tried bridged mode (using windows dial up) but not able to connect both the computers to internet at the same time.
thanks in advance:)
first of all confused with new name :P ! (netant) !anyways.. did you connect both the modem and the new stuff (ADSL Gateway) ?You neednot connect other Modem if you have this device !Bridge between PC and ADSL Gateway ?If you are connected to a system thru wire, you can use Dial mode I am bit confused.. Can you tell the current setup ? Phoneline=> ________>ADSL Gateway ?Are you connected by cables or only thru wireless ?Secured ?
No just the Linksys.
No bridged mode inside adsl wireless
I can use dial mode from any one of the comp (wired or wireless), while setting the linksys/router in bridged mode.
i can share the resource like files, printer, but not able to share the internet
:wall: simultaneously in both the system.
refer to image in post #4
Secured ?
My Desktop is connected in wired mode with the Linksys.
lappy is connected wireless.
i want this in dial up mode as im in night unlimited & i set it up everything to automatically dial my connection at 2:00 am, start download, disconnect at 7:59 am, & shutdown at 8:00. (in my workstation, lappy not used for download)
