Graphic design monitor around 20K
  • Thread starter Thread starter Realme
  • Replies Replies 11
  • Views Views 1,586
BSNL
Someone I know is in graphic design work specifically for print/news-paper advertisement design work, their recent workhorse has died so they need a new monitor as soon as possible on a tight budget constraint:
Specs Required(in order of priority):
IPS
24 inch (HD)
Prefer better Adobe RGB colour accuracy as they are in print work.
Static Contrast Ratio: 500:1 or 1000:1
Light Intensity: 300-350cd/m^2
Surface Type : Matte (No Glossy surface as it reflect a lot in his small office)
Lastly, should be easily available in INDIA, he is very risk averse to Online imports.
What I am suggesting is a 4K monitor BenQ EL2870U which is quite good IMO. It doesnt match all your required specs but offers decent performance.
I've a Dell 23 inch LED-Lit Monitor (P2319H). I use it for photo editing and basic graphic designing.
+1 for Dell P2419H looks good enought. The build quality is solid. Although I don't do graphic design but for gaming and day to day programming usage the screen looks great
His system old enough to not to be able to do 4K and neither he don't need it eitherway.
ProArt is way out of his budget(otherwise I would have recommended him Eizo ones)
@FujiwaraTofu Between the two you have just one at near 12 K and other at 19K, what's better if we remove all the other frills like usb, Audio ports,etc.. and just VGA port is enough
Also if I dilute down on light intensity condition, are they nearly equivalent?
btw why Amazon say display technology is LCD and not Wide Angle and for other some 3H coating thing?
Similar threads
