GTA Online Port Moderate Fix Help!
  • Thread starter Thread starter IRIE
  • Replies Replies 21
  • Views Views 2,277
Punjab
BSNL, NETPLUS
I am Using Syrotech 1110 Router Latest Firmware with UPnP enabled but my Gta online is stuck at Moderate nat
But Other game have Open Nat
Set NAT to 1 too in router too Firewal Low etc.
cany anyone help or have faced same problem
i have opened firewal etc allwed edge tranversal for gta5 in pc etc static ip on pc binded mac address on pc
@IRIE You don't need to put Firewall Low or other things.
Simple NAT 1 and restarting your router will make your Network Connection NAT Type : Open. I've been doing it for more than 2 years so it should be working for you.
But, If you are still getting Moderator NAT Type on NAT Type 1, You can try for Port Binding (as it will fix NAT Type issue too)
But, Why you want NAT Type : Open? For me, GTA Online work at NAT Type : Moderator & Close too (either at Co-Op or Multiplayer)
@Protector i was using NETPLUS fiber i disconnected it after they updated router and locked Admin Access which Disabled UPnP and blocking all port forwading thingies so i went back to BSNL which i was using before NETPLUS now i have this Problem of Moderate nat i have restarted Router Multiples times bruh but all other game like Ghost Recon Farming simulator etc have Open NAT except gta Online
Problem is getting disconnected while in a Heist with Moderate or Strict nat
Open nat does not have this problem
@IRIE all other game like Ghost Recon Farming simulator etc have Open NAT except gta Online
It looks like your Windows Firewall is doing some issue with Rockstar Launcher or Social Club to make it Moderate NAT (This is my conclusion only if you are using NAT Type 1 and getting Open NAT Type on other games)
@IRIE If you are getting NAT Type : Open on other games but not on GTA Online, It can be some protection protocols between ISP - Rockstar Servers which are making it Moderate NAT Type.
Although this shouldn't happen but if that's the case, You'll need to contact LCO to get it resolved by explaining your NAT Issue to him.
I have a Jio Fiber connection and facing issues with CGNAT. My use case is primarily online gaming. Jio CC says they only sell static IPs to businesses. Is there a workaround that can help me get a static Ip/enable port forwarding?
