Harddisk Info. Help! Urgent
  • Thread starter Thread starter Lokesh
  • Replies Replies 24
  • Views Views 6,031
QUOTE(blr_p @ May 28 2006, 11:47 AM) [snapback]52522[/snapback]
Whichever OS you use the most needs to be on the first partition. From what you said i would assume this is win98. What are you trying to achieve with drive letter changing. Seems you have a dual boot system.
Hmm, that site seems like a informercial for diskeeper, which tool exactly did you use test HD speeds, all i see are internet only tools available. My server does not go onto the net, so if there is some tool that can be run locally i can use that.
There are better tools out there for this sort of thing. Ones that are used in reviews for hardware, i suggest you give those a try as well. I'll let other members comment on which they are.
[/b]
FreshDiagnose stats for:
seagate 80gb barracuda (ATA-UDMA-5 enabled)
write=32.37MB/s (for seagate SATA 7200rpm shows= 30.11MB/s)
read=18.97MB/s (for seagate SATA 7200rpm shows= 44.88MB/s)
samsung 40gb (ATA-UDMA-5 enabled)
write=14.85MB/s (for seagate SATA 7200rpm shows= 30.11MB/s)
read=27.37MB/s (for seagate SATA 7200rpm shows= 44.88MB/s)
QUOTE(netfreak @ May 28 2006, 07:10 PM) [snapback]52548[/snapback]
Are these prices valin in Mumbai? And how much gurranty/warranry does these HDDs carry?
[/b]
Can't say ....But in kolkata this is the price.......
Yes Max Seagate harddisk comes with ......5 years limited warranty
Samsung gives 3 yrs
hey it's a nice software and i was able to verify the speeds of my HD's.they were the same as in the results shown on their page for my hard-disk.thanx buddy for the link and helping me out!
