I bought this fan Amazon.in in 2021. Paid about 6300 for 2 units.
In 2024 one of the fan stopped responding to remote and there is no other way to control it, I have tried some hacks but it didn't worked with my fan model. Now I am not sure when exactly issue happened because since winter season fan was running at 2 or 3 speed and remote was not used for many months, now when I wanted to increased its speed found remote is not responding.
Same remote is working for other fan so issue is with fan not remote. I have replaced remotes batteries as I first though it could be issue with battery.
Warranty was for 2 years.
Main issue with this or any BLDC fan is no local electrician knows how to repair it. I have tried 2-3 places. Havells repair person quoted Rs2000 for pcb and Rs250 service charge. Most likely the issue will be with pcb, I cancelled the request after knowing the charges. Main call support will not tell you about charges only technician can do that. You can call them before scheduling visit.
The technician quoted 1500 for doing it directly which is still a rip off and through company repairing will cost about 1800 if it gets repaired at all. And there is no warranty only 3-4 months directly or through company.
I can get a new fan same type BLDC for Rs 2800 Amazon.in so paying Rs 2300 for repair without any long term warranty is a complete rip off.
Main reason for getting this fan was less load on inverter but overall getting a normal fan would be better, electricity savings from this fan is not worth it in long term, a normal fan will last many years and very easy to repair. I have 20 year old fans still working. Even the other havells fan started making squeaking noise last year which is very annoying to me and unlike normal fan there is no way to put oil/lubricant spray.
BLDC fans are basically use and throw, if local shops can repair it only then it will be worth buying.
