This is a guide to connect
Nokia N95 / N95 8GB to your existing wifi network.
1. Configure your
ADSL modem to "Always on" mode... (look elsewhere in this forum to do this)
2. Note down the SSID and security settings of your modem...
N 95 / N 95 8GB
1. Click on Menu, Tools, Settings, Connection, Access points in that order...
2. Select Options under Access points...
3. Select New access point...
4. Give a name for your connection (any name to distinguish your connection)...
5. Select "wireless LAN" under data bearer...
6. Enter the SSID of your ADSL modem under "wireless network name"...
7. Select "public" in network status...
8. Select "infrastructure" in WLAN network mode...
9. Select the type of security in WLAN security mode (obtained from the security settings of your ADSL modem)...i.e., open, WEP, 802.1x or WPA/WPA2..
10. Enter the security settings in "WLAN security settings"...
11. Homepage... (leave it as none)...
To prevent your battery from draining out fast..
1. Click on Menu, Tools, Settings, Connection in that order...
2. Click on Wireless LAN...
3. Click on "Show WLAN availability"... (it will change to "YES" from "Never")...
4. Leave "Scan for networks" as it is...
5. Go to Advanced settings under "Options"...
6. Select "Yes" to acknowledge the warning that pops-up...
7. Do not change any field, except "Tx power level" which can be set to 4mW instead of 100mW...
8. Now come back to "Show WLAN availability" and select "Never"...
You are now ready to browse from your phone...
just select the access point... (some av programs like NetQin do not update over wifi)....
feedback please...
