just a few quick questions regarding the tentative price list (http://www.hayai.in/maintenance/hayai_in_201102.pdf) :
1) will the limited prepaid/postpaid data plans be 100 MB/s or 1000 MB/s? the site says 1000 MB/s but i thought it was 100 MB/s?
2) how do i select the most appropriate hayai plan considering i have been using 1 MB/s plans of hathway/mtnl uptil now and my average monthly usage comes to around 8-12 GB? i'm curious as to how this tremendous transition in speed (i.e. from 1 MB/s to 100 or 1000 MB/s) will affect my monthly usage?
3) how are these postpaid/prepaid plans on the left side different and which one is more ideal?
4) what is the "bill limit facility" for postpaid plans?
5) why are the hayai lite (wireless) plans of 8 MB/s so cheap compared to all others? do they function in a different way? can we use these plans on our regular home pcs? for example, the 20 GB limit @ 8 MB/s is just499/-
6) finally, what is the additional download charge rate per MB for limited plans?
thanks in advance matthew! hope u have a good time in india! goodluck!
1. The speed is upgraded to 1000 megabits per second. Yours is 1 megabit per second right? MB/s= megabytes per second.. 8 times that of megabits per second (Mbps or Mb/s)
2. The lowest flat-rate plan (with no hard cap) comes to around 1999, so you don't need flat rate. You can set a bill limit for 750 (550 for infrastructure, 200 for data) or so if you expect a usage of 20 GB or so..
As for the transition in usage, it depends on a lot of factors.
Sometimes it happens that due to slow speed we cannot do some things although we want to, but as soon as they become possible then we tend to do them first. For example you wanted to download a 8 GB BRRip of your favourite movie for months. It would take a lot of time to do on 1 mbps but will download in minutes on connections such as 100 mbps and 1000 mbps..
Another factors is your budget. If you do not want high usage and want moderate speeds(5-8 mbps) and have a low budget as well, I'll suggest you go for Hayai Lite. It has low costs of infrastructure and so the plan cost is lower to you. However there is one problem in that.. I'll come to it later on.
If you have a budget of around 1000 then I suggest you go for full speed data plans.(You'll get 45 GB)
3. Prepaid is in only one form - data plans. Pay and use. You purchase data worth say 100 (10 GB) and then use it. once all the data is exhausted you can visit only Hayai sites and will be able to recharge your account via the portal. Then you can access normal Internet again. Also the data has a life as well, which means that you can buy 10 GB and use it for upto 1 year from the date of purchase.
Postpaid plans are for people who do not want the headache that the data bought is going to expire one day and we need to recharge it in order to access the Internet then.
These plans start from 1999 and are of the type "Use how much you will, but still think a bit about us," which means you should not( I do not say cannot) download more than your fair share (It's sufficiently high, don't worry). A bit expensive for light users like you. One striking feature is that for a flat rate plan the bill will not come higher than 1999 for the lowest tier no matter how much data you use.
These tiers are as follows:
Speed(mbps) Price Fair Share(GB) Equivalent data if infra taken into account(GB)
5------------1999--200--------------145
10-----------2999--300--------------245
25-----------3999--500--------------345
50-----------4999--700--------------445
100----------6999--1000------------645
150----------9999--1000+----------945
One important point to note is that the cost is 1999 including tax including infrastructure, which means at the end of the month you'll have to pay not a penny more than the indicated amount.
You can use more than the fair share, but remember, the more data you use, the more you eat into the company's profit margins, and a stage comes when you cost the company more than you pay them (like when you use 500 GB on 1999 plan). and so after 3 months of "overeating" the company will call you and try to make some kind of a resolution( make you shift to a higher plan to suit usage, in this case the 25 mbps one) or if you do not comply, force downgrade plans in the case which you will not be able to upgrade for 6 months.
However, don't fear-- these are all extreme cases and last resorts.
To answer the second part of your question, it's on you, if you are a low user and not so torrenty you can go for hayai lite else data else flat rate.
4. Bill limit facility is for prepaid plans only, the system puts a limit on your usage (which you specify of course) and you can use data upto that limit without having to actually purchase any data. In other words, you can use 25 GB data in a month, if the bill limiter is set to Rs 800, without actually having to buy that 25 GB first.(in which case your bill will come to be Rs 800 instead of Rs 550 when zero data is used.)
You can set the limiter to any value you wish from Rs 560 upto Rs 10,000.
If the bill limiter is reached, you can no longer use data until you buy and recharge, in which case the limiter is turned back by the appropriate amount.
In short, a hybrid between data and flat-rate.
5. Because of low infra costs. You can buy 30 GB in Hayai lite for monthly usage for Rs 649 only which, for fiber is Rs 850.
However, some disadvantages of wireless:
-NO 1000 mbps.
-speed attenuates fast (You can get upto 30 mbps near the tower, but the plans are designed for 8 mbps due to the distance problem.)
-NO(or low) bittorrent as wireless is crap when it comes to multiple links, on which BT is based.
Wireless plans are provided through a usb dongle(which you see in the ads for photon and docomo). It is capable of 40 mbps down, 6 up.
You can use them in your pcs as well, it can connect to any pc as long as it is in suitable range.
6. Sorry, the wireless plans cannot be recharged, once you use the 5 or 10 or 20 or 30 GB, that's it for the month. You'll have to wait till the next billing cycle. (This is the one I was talking about in (2)).
This is because of the simple reason that the network will become too congested if recharging is allowed, and also the plans are for people whose usage is between 1 to 20 GB per month max( like casual surfers and social networkers, and using for office, like my sister does a job and needs wireless internet)
Well, I'll tell you on behalf of Mathew that we value your continued support and thank you very much for your regards.
-NO 1000 mbps.
