[help] how to configure mt841 for airtel wifi?
  • Thread starter Thread starter samthebest
  • Replies Replies 26
  • Views Views 5,759
Pv4 Address. . . . . . . . . . . : 192.168.0.1(Preferred) ?????? 192.168.1. X
Default Gateway . . . . . . . . . : ????? should be 192.168.1.1
Problem here.:
In modem Presume you have enabled DHCP and given range 192.168.1.3 to say 192.168.1.30
In computer Network WLAN properties window
ontop wlan box select Configure
ensure enabled. check other settings if familiar.
select tcp/Ip properties
Obtain Ip address automatically
Apply Save.
recheck
feedback.
Why you disconnected ? trying again. MIne 560 0XX 5XXpassword here later.sorry. Please try after 1630PMpost new password.
0458 seems wireless is ok. You have to try without lan cable.Mine windows 7 lan always connected in PPPoE mode.( auto connection )or use the HP wireless facility to switch either lan/wifi connection waiting for report.
0513I cannot see the HPwirelessUtility icon in task bar) or press f10 key remotely.without lan cable try to check whether WLan is enabled.waiting for report.
when i connect to wlan , the icon shwos local only instead of local and internet
and u should check the adsl settings...are they correct???
i can conect 2 wlan without lan cable
