I have checked my network setting in my laptopDell latitude 5400 modeland found adapter is Intel® Ethernet Connection I219-LM..PFA image for your reference.
Alright. Then i guess either the bandwidth has not been updated at bsnl end. Try contacting them. See on data usage check page whether your mentioned plan is activated. For my circle is address works for data usage. 172.30.139.25:9090/ssssportal1/manualRedirection.do
Thanks bro..yes plan got changed in bsnl side..I have verified in self-care portal...bsnl team raised escalation to higher team...and they are not able to fix it...trying from their end..too
Bro ..as I told u sterday..1gb...in the Ethernet status general tab sterday morning..but again they asked to reset and I did now I m checking ethernet status it s showing 100 mbps..got confused...
