help required in checking latency
  • Thread starter Thread starter surajch
  • Replies Replies 1
  • Views Views 1,911
surajch
hi all, i am trying to setup a point to point voip from my parents in NOIDA to dubai , need help in acessing the latency between the two points can some one using BSNL Dataone service in NOIDA / GAZIABAD ping the following domain post the results for me here , Domain to ping : dxb.homeip.netAppreciate the help Also wanted to know if it was possible to have a bharti connection in NOIDA , i believe bharti has a lot more international bandwidth compared to BSNL , so i assume the ping times will be much lower in that case from Airtel broadband,
Pinging dxb.homeip.net [217.165.56.36] with 32 bytes of data:Reply from 217.165.56.36: bytes=32 time=187ms TTL=235Reply from 217.165.56.36: bytes=32 time=169ms TTL=235Reply from 217.165.56.36: bytes=32 time=176ms TTL=235Reply from 217.165.56.36: bytes=32 time=169ms TTL=235Ping statistics for 217.165.56.36: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 169ms, Maximum = 187ms, Average = 175ms
