Hi,
My BSNL ftth connection was setup yesterday. I picked up a Digisol DG-GR6010 ONT and can connect via the Ethernet port. However I am unable to figure out how to connect my Mi 3C router to the modem. The BSNL tech guy says, it is not possible because the Mi 3C router does not have VLAN and a router with VLAN settings is required. Can one of you confirm the same. I have tried switching off DHCP in the router settings but could not make it work.
Also I am reading the ONT / router has to be in bridge mode. Buy my modem setting only allows for Route, there is no other option and same with the router settings
Thanks
Thanks
