Help.want to connect 3 pc's with bsnl type4 wifi modem-manufacture ultrascom
aryanchinha
BSNL
Hey people.I have a bsnl dataone connection with home 750 unlimited plan,and a ultrascom type 4 wifi modem.i want to connect a laptop using windows xp,and 2 desktops using windows vista ultimate with this modem to share my internet connection.my modem has 4 lan ports,and a dsl port.the guy frm BSNL told me that i should able to get internet connection simply by connecting the three machines with modem with lan wires.But i couldnt establish the connection on laptop using xp,and between the two desktops,only ONE AT A TIME CONNECTED AND THE OTHER ONE WHEN TRYING TO ESTABLISH VIA PPOE,SAYS USER NAME PASSWORD NOT PRESENT IN DOMAIN BEACAUSE OF REMOTE ACSSES ERROR.I have tried all modem tweakings in firewell,allowed remote desktop connections but failed.PLZ HELP.....:cry::frown:.....by the way,the laptop and any desktop does not support any kind of wifi connection,i wanna do it by wired lan.CAN IT POSSIBLE?
You need to set your modem in PPPoE (Always On) mode in order to connect all 3 machines at the same time.Search the forum for details on how to setup your modem in PPPoE (Always On) mode.
http://www.calcuttatelephones.com/dataoneinstall/drg07.html
Mention the model/make of Type IV modem/router
supplied by BSNL .
select here your unit::
BSNL BROADBAND MAIN MENU
Para two:
(a)If you are connected to one computer No.1, remove RJ45 cable from computer1 ethernet Port and connect to
WAN port of modem.
connect all computers to different LAN1 , LAN2, LAN3, LAN4.
(b)In all computers
Start/Network/LAN properties tcp/ip
properties
select Obtain IP address automatically.
(c) In modem enable DHCP.
Reference: Another Type IV.
New Page 1
Ok buudies.Thanx,at last i succeded.I checked the ethernet cables,and made the connection ALWAYS ON.Used the vista firewell to connect other pc's through my computer and also enabled DHCP in modem.Finally it worked.:thumbsup:Spcially i am thankfull to Sahyadri and essbebe.
