im using speed b/w 40-50kbps wid home 750 ulline rate is over 11 mbpsbut snr margin is only 7.0dBwhereas i get 20-25 dB in 500 UL plan.anyway to increase the snr margin???
Try this. Change the Mod type to GDMT. or adsl2 or adsl2+ or T413 and keep the one giving higher SNR and( sync line rate also may lower.)Just report D/L mod snr attn line rateQuery : are you using the same modem for both plans ? ? Which telephone line is newer ?
/members/adi-1994/I am not a "KNOW ALL" but know very little. Now Xavi modem , there are so many. You could be using it in USB mode.1. Modem Xavi Model No ???? USB mode ??? 750UL snr 7 db line rate 11mbps mod selected ??2. Modem ???? Model No ???? Mode LAN ?? Home 500 snr 20-25 dbQuestion about modem/telephone line not answered.
Para two : suggestion: see the post you want to answer .
use [quote ] blah blah [ /quote] without quotes will appear blah blah
Type you reply in notepad. check the draft. reedit. Then copy paste here.
