Help with ZXDSL 831Aii
  • Thread starter Thread starter adi.1994
  • Replies Replies 26
  • Views Views 7,611
adi.1994
Dataone(BSNL)
the modem sometimes works in always on mode and after sumtime it gets disconnected and internet light goes off.i use bridge mode and it works sumtimes and duznt work sumtimes.wat shuld i do to solve this, do i get a new firmware, itried google but could not find any firmware.is there any way i can increase the speed im getting b/w 220-260 kbps in both zxdsl and xavi x7721r+ which i configurd myself which was left with me given by vsnl which i had a long time ago.i hav 500 ul plan.in my friends house he has 125rs paln and he gets speeds b/w 400-600 kbps.
I am having problems configuring zxdsl 531b into pppoe mode.. i mean always on mode.. it never worked with me .. tried to see zxsl 831 pppoe configure post and do but was never successfull.. anyone pls help me
d/l limit is 150MB. Warn him to watch/check the download. data so far. He will land with a big bill. at least use shaplus 1.1 meter.
see link https://broadband.forum/bsnl-broadband/22290-bsnl-broadband-billing-problems/#post184528
I think speed for this plan is upto 2 Mbps.
If you are having Home 750( old Home 900)max speed is 32 Kb/sec 256Kbps speed.
@WizZ In wan page disable "bridged" User ID without @ bsnl .in VPI/VCI 0 and 35. etc.
Use tags and search for your modem threads. @ Onlytest has posted detailed screen shots.
for reference:https://broadband.forum/tata-indicom-broadband/9112-help-need-configure-tata-indicom-modem/
modify data suitably for BSNL>
this problem seems to be related with your line and/or bsnl server.
is this problem same with both modems?
/members/adi-1994/i hav 500 ul plan
Presume you have Home 500 with NU free.
CONFIRM the tariff plan Home 500 Home 500C home 500 C+ Home 750U/L etc.
Confirm which modem you are using at present.
Para two: Post SNR attn data for both modems. ( if in service )
Check all cables for oxidisation/corrosion and if needed replace them with short cables.
can u make a REMOTE DESKTOP CONNECTION session with your computer using ultravnc or realvnc so that i can access your computer and the ip address 192.168.1.1, the modem you mentioned is slightly different than mine (zxdsl 831AII)
download realvnc free edition or ultravnc, install it, then configure server by entring access password. give access through firewall, then inform me when you could be online, then you and i, both will online. pm me the ip address. i will then be able to connect you as remote administrator.
click start/all programs/realvnc/vnc server usermode/configure realvnc server.in setting property page click vnc password authentication then click. then enter password. then click all programs/realvnc/vnc server usermode/run vnc server.pm me your password and ip address of internet.
