home 900 issue-plzz help
  • Thread starter Thread starter tavleen
  • Replies Replies 14
  • Views Views 2,088
tavleen
bsnl
hi i am usin home 900 unlimted 256kb plantin is i keep ma system on most of the time(sometin is always seeded or leached on ma system)wat i really want to know if there is a way i can remove the user name password dialin on ma system as sometime ma system gets dc at nite and everytin pauses p.s i am usin Huawei quidway wa1003a modem
first of all, you can type full and proper sentences and words. no use using SMS typing to save a few bytes since you are on the unlimited plan.now to try to answer your question (if i read the SMS lingo correctly), is that you can enable a firewall and open only the ports your need (torrents etc), and also set your modem to do PPPoE dialling rather than bridged mode...ps:... you are misspelling "my" as "ma"
oh i am sorryall i really want to know is if i can remove the dial up connection which is needed to connect to internet so i am connected to internet always (i.e when my system is turned on )
are you able to get to your modem's web configuration page at 192.168.0.1 or 192.168.1.1 ? i hope this is the same for your model...there you can provide your username/password for PPPoE mode and set your PC to "automatically obtain IP address"... maybe someone else can post details...
Power failure while editing.
@tavleen
See web site1 (Add to favorites.)
Quidway WA-1003A ADSL MODEM MENU wa 1003A
Open the modem page select PPP/PPPoE .
Enter your User ID without @ dataone.in or @ bsnl.in and password
Enable "always on"
Save and reboot. Wait for 2 or three minutes.
Check in the night your torrent sites .
IF Now more problems about portforwarding. !
see web site 2. !
PortForward.com - Free Help Setting up Your Router or Firewall
Update :1652
You want your Modem to be "Always On " or Check your Usage ?
