villamagna
The Linksys WAG120N is very easy to install and use actually , easiest way to install this router is through the setup installation CD comes along with the package. However, you can install and configure this router without the installation CD as well. Installation of WAG120N using the CD is quite self explanatory. All you need to do is to place the Setup CD on to your deskopt/laptop and follow the simple step by step instructions (with pictures) and it will be done in a few minutes, even for a novice user. Please be careful to follow the instructions exactly the same, else might get into some troubles.
To install the WAG120N without a CD, follow the steps below: Linksys by Cisco WAG-120N Wireless Modem Router Installation,Configuration and Troubleshooting tips | Netnlap Blog
