I relocated to a new home where the Jio ONT doesn't cover the entire home. Hence, I purchased 2 TP-Link Wireless Range extender RE200s (Physical LAN was tough to pull off), assuming it would solve my issue. I
t works decent with only few wifi dead spots but I ended up with multiple SSIDs and it's a major pain especially when on a VoIP call and roaming around the house (automatic networking switching takes time). I need to setup a robust Mesh system with a single SSID.
I am thinking of buying a TPLink router that will be connected to the JIO ONT (in router or AP mode?) via LAN in the same place. As I got to know that I can't do away with the JIO ONT.
This 'redundant TPLink router' will complement my RE200s to create a mesh network (TP Link requires their routers for One Mesh).
- Am I better off buying a TP Link router, or should I consider TP Link Deco for my use case?
- Any recommendations for a dual band TP Link router that supports one mesh (I don't want my purchased RE200s to go to waste)
- Any tips / reviews for TPLink's One mesh? Does it work as well as advertised?
