how do i insert and remove the card in sun-CPE?
^OK :yahoo: I got activated and the pic quality is verry gr8 yaar!
@vin arun:I got STB changed it before activation!so make sure u do all ur testing and updating the irde firmware version to latest etc and if the STB fails random reboots,then go ASAP for a replacement before they register and activate ur connection :) i have to talk to them for sometime to get replacement.still,the previous STB is NOT at all bad! and the randome reboot is found in STBs with High temps!
and just to clarify,i heard most of these STBs hangs if u play with fast menu changes via remote!also the random restart got chances like 0.1% for any user!dont worry! :p
^I heard from the distributor that from this week or so onwards,sun direct is gonna give a new STB and a bigger dish for the customers :oops:
also they are opening activation centre in Kozhikode,kerala.
Q: Can we able to get channels from any of the satellites listed in STB :?: please help and let me know what all channels!(FTA) :) Thank you all!
_|_
you can try nss on 95 degree east, you will get live india, etc pujabi. Refer Satcodx for TP. FTA in Ku Band in NSS you can recieve.
Thank yoU!also can i store these channels of both insat and nss together in STB ?please i dont want to move the dish directions :)I tried manual searching and got all DD channels added up!
Are you able to see NSS6 in the channel list after the Firmware upgradation? That satellte is missing in my STB
