I have Airtel ISP and I am about to connect secondary router to extend my WiFi range in my house. As I search thru google. somebody says bridge mode, somebody says wireless AP method to extend WiFi range. Also some says disable DHCP in secondary router, connect cables primary router LAN port to secondary router LAN port ?? some says primary router LAN1 to Secondary router WAN port ?
How many ways to connect secondary router to extend WiFi connectivity by wired connection.
Why all these methods are using ? Which is the best method which particular usage ?
May be I'm confused about what I said above.
Thanks.
Thanks.
