I want to keep only the wired link enable and disable wifi totally on my 777VR1. This is due to health reason (I am trying to cut down on electro magnetic radiations). Is there a way to do so on this router?
There should be an option to disable the wifi altogether.
Edit: Found the steps. Do the following in the GUI. Click Setup --> WLAN on the left -- under Basic -- check the first option "Disable Wireless LAN Interface"
1st and easy mothod-there is button to do so on backside of 777vr1. press it for 3 second- wireless light on modem disappear.
2nd- login to modem consol page by typing 192.168.1.1 it will ask for username and password type admin in username and type ur account no in password. when you successfully entered in console click on Setup then on left panel you will get wireless option which brings two options first wireless basic and wireless security. click on wireless basic you will get check box to disable wireless
