Beetel has QOS? Oh, I searched and found it's TP-Link TD-W8951ND underneath.
This is one complicated QOS. I don't know from where you can control the bandwidth. The settings are not clear from just a picture.
Still this is what you need to do,
This is documentation for the router > http://www.tp-link.com/resources/document/TD-W8951ND_V5_User_Guide_1910010890.pdf
QOS is explained on 47 page.
Well, QOS doesn't tell you how much data your and his computers has crunched. You can get this info in Status tab. You'll need to turn on data logging as it's generally turned off. Before you do that you need to set time for router because I think it's important that router needs to know data time for logging the data usage. To set time go to Maintainance tab > Time Zone. Choose ntp server automatically etc.
I just thought of another way you could keep track of data usage.
Just install netlimiter software on your computer. It'll keep all data usage info saved in a database. You'll know how much data your computer ate by the end of the month. Subtract that from the data usage shown on ISP website and you get the data consumed by your neighbour.
Remember all kinds of data access like internet, LAN file/printer sharing is logged by both software and router so it won't be accurate if say you copy songs to your phone over wifi from your computer as it'll be logged too.
