Login to router
Go to Firewall->NAT Forwarding->ALG Switch-> Turn on SIP, H323, PPTP, L2TP, PPSEC and click on save.
Create a Static Route/Route in your router settings (MUST)
Destination Gateway - 10.0.0.0
Subnet Mask - 255.0.0.0 or 255.0.0.0(/8)
Default Gateway - You will find in WAN connections (Check for VOICE tick marked one tab {DASAN H660GM-A it's WAN1 by Default})
Metric - 1
Interface- Select your VOICE configuration enabled from list. (for DASAN H660GM-A it's WAN1 by Default)
Status - Active/Up/Activated click on save.
Go to Maintenance->Logs->System logs (Search here for SIP- and find you landline number, Here you will see proxy details, port & password take note)
PC Setup - Install MicroSIP-
Account Name - +91Your_Landline_NumberWith@ue.ims.airtel.in (ex- [email protected])
SIP Server - 100.xxx.xx.xxx (Advanced Setup->WAN Connections->WAN1 IPV4 address or You will get this from system logs when you search for SIP- look for SIP/2.0/UDP 100.xxx.xx.xxx:5060;received)
SIP Proxy - 10.x.x.x (VoIP -> SIP Proxy address Or You will get this from system logs when you search for SIP- look for Sending 2 bytes keep-alive packet for acc 0 to 10.x.x.xx:5060 Or UDP 10.x.x.xx:5060)
Username - +91Your_Landline_NumberWith@ue.ims.airtel.in (ex- [email protected])
Domain - SIP Server:5060 (Ex- 100.xxx.xx.xxx:5060)
Login - +91Your_Landline_NumberWith@ue.ims.airtel.in (ex- [email protected])
Password - Nokia@1 (This pass will only work for DASAN H660GM-A)
Transport - UDP+TCP
Tick Allow IP Rewrite
leave rest as default do not change.
Hit Save - You are good to go. Enjoy
Metric - 1
Transport - UDP+TCP
