I need help on bsnl ftth wifi settings thingy..
  • Thread starter Thread starter DMC
  • Replies Replies 6
  • Views Views 1,926
DMC
Shivamogga
BSNL FTTH
AIRTEL 4G
BSNL 3G
Hey guys, i opt a bsnl ftth connection & my plan is 50mbps(750GB) , on lan cable iam getting 50Mbps but on wifi i am getting 15Mbps, i asked the local csc they said dont use wifi use lan cable ? like wtf ? is there any other option or settings that i can work on ? thank you:) .
I have a Digisol router, & Bsnl Franchise people came & gave connection & I bought the oNT modem from Netlink website , it was working fine until lockdown from mid May I started getting 15-20Mbps on wifi & I asked the franchise people they said please use lan cable to use internet don't use wifi.
You can use the Digisol router as a Wifi Access point keeping the Wifi of the Netlink off ...take the connection through LAN
Method 2 :- You can completely bridge the ONT to the Router if the Digisol is a recent one and has good capability
if its a ADSL router then you cannot bridge it I assume
