Imgur uploads are not working me either but I'm able to access pinterest and other blocked sites by just forcing https. If you couldn't then a proxy or a VPN will be the only option.
Yesterday, I was unable to login to my Imgur account from BSNL 3G. I got the following error msg when I tried to login:
{"data":{"error":"Imgur is temporarily over capacity. Please try again later."},"success":false,"status":500}
I then used a VPN, with location set to USA. I was able to login fine.
I contacted Imgur Support about this. They answered the ticket promptly:
Feb 27, 11:55 MST
Hi there,
Thank you for reaching out to Imgur Help. Unfortunately we’re experiencing temporary errors in your region, which may result in access issues on some Imgur features. At this time, we’re investigating a long-term solution to this problem.
I apologize for the inconvenience this has caused and appreciate your patience.
No. Imgur has been like this for few weeks now. I couldn't log in and when enquired, I too got the same reply above from them. I think they blocked loggin in from India (Don't know whats the reason)
