Innos D6000 (comes with a 6000mAh battery)
Navjot Singh
The company uses a unique ‘double cell structure technology’ which comprises of two batteries. One of them is internal featuring a 2480mAh capacity and another is external and replaceable, with a 3520mAh capacity. Furthermore, the user can easily swap the external battery without having to power down his phone. According to Innos, this will deliver power that lasts between three to five days per charge depending on use.
It also makes use of a special DuoCharge technology which uses the built-in chip to allow parallel charging of two batteries. This technology allegedly reduces the heat while charging and prolongs battery life.
The smartphone features a 5.2-inch 1080p display protected by Corning Gorilla Glass 3, a Snapdragon 615 1.8GHz octa-core processor, a 16-megapixel rear-facing camera with a 5-megapixel front one, 3 GB of RAM, 32GB of storage, dual-SIM standby mode, USB 3.1 Type-C connection port and Android 5.0 Lollipop.
Price: 1799 Yuan ($290)
Mediatek version with 2GB RAM: $161
