Is it true bridge mode
  • Thread starter Thread starter Ejaz
  • Replies Replies 15
  • Views Views 1,568
India
BSNL
I am getting 10.212.x.x after 192.168.68.1 in doing tracert.
Everything else is okay.
Am i double natting?
Or is it bsnl part?
My modem is genexis and router is TP-Link.
@Ejaz 10.xx... series normally doesn't belongs to routers in india. You must be in bridge mode with Isp having CG-NAT .
No BSNL doesn't CGNAT the connections yet. If you have public IP address then you're fine, maybe the 10.x series is from the local OLT
How to check if you are provided with public ip if traceroute is showing 10.xx.. after home gateway ?
