Is such low speed normal in Kolkata? please check
  • Thread starter Thread starter arnab_g
  • Replies Replies 6
  • Views Views 1,907
arnab_g
BSNL
I am regularly getting such low speed in last few weeks and even lower than that
I am based in Kolkata and having Home 500C+ plan. Is this normal in Kolkata?
What other home users of Kolkata 500C plan getting? please mention here.
Also I am getting a download speed of 10-12 KB/s for most hosting service like RS, MU, EZ. What other people getting?
Hope to see your comments here :eek:
arnab_gNot normal. Below expectations. Let the cable repair issue settle and then revisit this topic if the speed stays low.In the meantime:1. Make sure your ADSL setting is G.dmt and not G.lite, ADSL2 or something else. Save and Reboot ADSL modem for settings to be permanent.2. Use a splitter correctly.3. Post a screenshot of SNR and Attenuation as seen in the modem.Also try the speedtest at some other server (Singapore). Test at dataone.in as well. What figures are you getting from dataone.in speedtest?
Please see below -
1. my ADSL setting is G.Dmt
2. splitter is ok
3. here is the screenshot
http://img68.imageshack.us/my.php?image=192168111ol7.jpg
4. Here is the Singapore result
5. I am seeing many recent posting with speedtest.net result where users getting 900+ kB/s. If cable cut is the reason then how can they get 900 when mine not crossing even 100 :huh:
6. dataone.in speedtest very unreliable. it gave 241 kbps, 3400 kbps, 2385 kbps in three test within 5 min gap. :mad:
Would like to know if other users (specially from Kolkata) also getting such low speed. plz let me know here
I would say it is a line fault, your Downstream SNR is low... the ideal value is around 20-25dB ... So get your line checked out
Could be a local issue. If no one from Kolkatta responds and things do not improve in 48 hours, file a complaint with BSNL. Actually, go ahead and file a complaint tomorrow morning itself since it can take BSNL some time to respond.
