Does BSNL have backbone to provide 1 Gbps?
Backbone wise running 10G/40G/100G to cities is quite feasible. Bandwidth is typically not major challenge on backbone level as long as one can pull sufficient fiber in. It's usually a challenge where fiber is not present or hard terrain hilly areas or when it's for last mile in low density areas.
With DWDM one can easily increase bandwidth to great extent.
When do we see such speeds like 500 Mbps or 1 Gbps with BSNL in future?
This applies to BSNL, Airtel, Jio or just any major operator. It's purely case of demand and supply. ISPs could do 8Mbps easily on most of old DSL infra but they did not do for a long time and instead had plans from 256Kbps to 2-4Mbps. In most of cases it's the economics behind the plan. How many extra users do you think BSNL can get if they offer 1Gbps for an attractive pricing of say 700-800Rs a month? How many of those users would only purchase service if they can get 1Gbps and will not consider 50-100-200Mbps kind of plans? For now answer to those questions is - "Not that many". If you check their plans, they do offer 300Mbps for 1499 a month. If they offer 1Gbps for 700Rs, what happens to this premium plan? Should they give 3Gbps on that? That's hard one because home interfaces, PON CPE side interface etc is all 1Gbps. Plus there's a high chance person would just downgrade from 1499 to 700Rs plan and live happily with 1Gbps. So at the core of it you have to ask question "What is one an do with 1Gbps which one cannot do with 100Mbps". Right now not much but as that changes, you can expect 1Gbps plan. In absence of that offering 1Gbps would just put a bill of upgrades, extra capacity to serve peak with no realistic returns.
Why do BSNL have higher ping compared to other fibre operators?
This has been discussed extensively on this forum. Try searching for previous discussion or you can check my blog post about their routing issues when I left their service -
BSNL AS9829 – A rotten IP backbone
Broadly it's due to following:
- BSNL is quite poorly peered compared to other networks inside India. As a large eyeball and inbound heavy networks, they should have been peered with all large content players but that's the case.
- BSNL has IPLC - basically long point to point circuits from India to outside world and they took large capacity on circuits to New York and Los Angeles. They take different upstream providers in those locations and thus end up with many circuits, many providers. To fill up on this capacity they announce specific prefixes and that results in cases where for any network in the world (outside of India) to send traffic to BSNL, only entry point happens to be a gateway in New York or Los Angeles. This impacts routing from nearby areas including Singapore, Hong Kong and even Europe.
- While other large networks of that size typically peer outside of India, BSNL never peers outside of India and just buys capacity. Peering by design keeps traffic local and typically would keep routing clean for 99% part.
- BSNL doesn't uses BGP communities on their circuits outside of India and use one set of provider at one location & other set at a different location.
- Airtel doesn't accept BSNL routes in South India and in many of those instances routes to BSNL from outside of India. That again results in issues of high latency.
Thus it's lack of overall traffic engineering, good practice etc which creates a not-so-good routing.
