Limited or No Connectivity. Pls Help
dennisrobert
Dataone
Just an hour ago, when i click to connect, it simply stays as "connecting through WAN Miniport PPPOE" for some 30 secs and then says "Remote Computer Does not respond". I switched off my modem and then i see the local area connection searching and then with a yellow exclamatory mark it says "limited or no connectivity". What is this?The power,ethernet,lights are glowing still.I cant get connected.my ip address is of 117. type.
/members/dennisrobert/Welcome to broadbandforum.coPresume setup was working alright earlier . Check cable connections. Run diagnostics test in your modem. what is the modem model ?Default gateway not available.Start/Network/Local area connection/properties/ (Repair option ) TCP/IP check settings. Start run type cmd type ping 192.168.1.1.
Do following steps.Step#1ipconfig /renewTry to connectStep#2type services.msc in run mode.Select DHCP client. Stop the service and then start.Try to connectStep#3config again in 192.168.1.1Try to connectStep#4 Try step 3 and step2Step#5 call CC to 1500
Hi,Thanks very much .I pinged 192.168.1.1 and the response was 100%lost.I dont know how can i run a diagnostic test on my modem.I cant find anything in device manager except my dial up modem which is what am using now.Anyway its WAN Miniport PPPOE..and the modem is ADSL by ZTE coperation. ZXDSL 831AII
Info :Modem ZXDSL 831AII
You have not confirmed whether your system was working earlier, and you made any changes . Difficult to give one sentence instruction , and you have to check completely your modem configuration and LAN set up in computer.
Start Run type cmd type ipconfig/all post results.
Please see this thread and check the instructions given by @onlytest.
Zte Zxdsl 831aii Modem Configration - India Broadband Forum
configration/
Number of screen shots also posted.
Add this link to your bookmarks for reference , whenever required.
If you open the above thread , without log in to IBF all screen shots will be seen.
this is my ipconfigIP Routing Enabled-NoWINS Proxy ENabled-NoEthernet Adapter LANConnection specific DNS Suffix.:Description:NVIDIA nForce Networking ControllerPhysical Address........... 00-1B-FC-AB-78-30Dhcp Enabled-YesAutoconfiguration IP Address - 169.254.181.116Subnet Mask........... 255.255.0.0Also when i click the REPAIR option in LAN, it shows "Renewing your IP Address" and after some 1 minuite it ends up saying "Cant repair as windows cannot complete the following action:-"Renewing your IP addrress "I havent made any changes to my system.It was working fine upto 7 PM today.Then i removed all the plugs and power cables as there was huge lightning over here.After that, this is the problem.. I am now checkinginto the link u have posted above.Thanks
Are you in a private LAn network ? subnet mask also not correct. should be 192.168.1.x (say 3 to 20 ) subnet 255.255.255. 0 default gateway 192.168.1.1
Start/Network/Local Area network/Properties/TCP/IP
Obtain Ip address automatically.
enter the following DNS ( open dns for all isp's
208.67.220.220 and 208.67.222.222
and try.
For modem checking In IE type 192.168.1.1 admin admin
I am now accessing internet using my dial up connection via PCI modemIs that why my ip address and subnet are wrong?I typed the DNS address u gave and its still the same. "Limited or No Connectivity"with a yellow exclamatory mark.Speed-10.Mbps in the taskbar.When i click to connect for broadband, at the end it says"remote computer doesnt respond"I disabled my Lan and then enabled it a while ago.Still its the same yellow exclamatory markSubnet is 255.255.0.0And page is not loading when i go for 192.168.1.1 using this dial up
Go to Network ConnectionsRight Click "Local Area Connection " > TCP/IP Properties Select Use the following ip address and enter the followingIP Address : 192.168.1.2Subnet : 255.255.255.0Default Gateway : 192.168.1.1Preffered DNS : 208.67.220.220 and 208.67.222.222NOw click ok and exit out of all that screens. Now your LAN would not say Limited or No Connectivity. Now go to command prompt and try pinging the router. If it replies then login to the modem and probably you will have to reconfigure. If your modem still does not ping then you will have to reset the router and try again and once it start responding you will be able to login and reconfigure the modem.
@/members/dennisrobert/are you using USB port ? see post 7 & 9TCP/IP settings are different for dialup modem and Broadband modem.You don't have to connect to internet to access modem settings in.. 192.168.1.1. (Delete all tempy files in IE.)Make the changes in TCp/Ip. Disconnect dialup ( sancharnet or Netone)Connect zxdsl modem and dial . If "no go" check BB modem settings.
