Low Speed with BSNL Home Combo ULD 999
  • Thread starter Thread starter rydraj
  • Replies Replies 29
  • Views Views 18,088
Billing will be on pro rata basis. ie, if you go are using a Rs. 1,000 pm plan and switch to Rs. 500 plan on 16 th. You need to pay
1. (15/30) x 1000 = 500
2. (15/30) x 500 = 250
Replace the no. of days in a plan and rent in the above equation. So that you will get your total.
Your plan BB home combo ULD 999 is having speed of 4 Mbps and how can you get 8 Mbps speed ?
Check below link of your plan parameters..
Broadband Combo Plan
And if you want still higher speed..go for VDSL connection instead of ADSL , which is having starting plan 1745 monthly with 8 Mbps speed.
jai, I stay in Hyderabad, Telangana(Once AP). Plans here are quite different than what you get in other states. Please bear that in mind.
8 Mbps till 60 GB for 999
I was getting till 8 GB for 4 mbps with 950 plan till few months back in Kolkata. Now I shifted places and BSNL wires are not laid in the new complex till now.
Lucky you.
MF BSNL... In HYD, they can give 8Mbps speed till 60GB and 2Mbps then for just Rs999/- and in TN, they are just giving 4Mbps till 8GB and 512kbps then....
I know in Hyderabad, competition is kicking their a$s, but this difference is too much that looks like BSNL is milking rest of Indian customers...
