Maybe a possible way of fooling MTNL, community help needed.
  • Thread starter Thread starter tutsipoppy
  • Replies Replies 43
  • Views Views 7,016
tutsipoppy
MTNL - 256UL Combo
Guys i may have accidently found a way to hack or get through MTNL's stats, whereas ur session won't be recorded. It happened accidently, but i still dont know how exactly i did it, im still trying. I guess u guys can also try and see if u can find the exact way.
Last evening, i was simply surfing on my computer and the time was around 8pm. Suddenly my computer hanged, so i had to restart but i didnt switch off my router. The computer restarted, i again started surfing normally. Now, i didnt disconnect before 12am coz i was chatting, so i realized the time and switched off-on my router at around 12.11am. So today when i checked my session summary, i noticed that my session from around 8pm till 12.11am wasnt recorded. The stats are last logout time on 18th is 8:32:54pm and then the next login time is 12:21:49am. Whereas i was online between that time frame, surfed web and was chatting over msn.
I'm sure we can get through MTNL, we just need to exploit it.
One thing i noticed that my last session on 18th was exactly of 8hrs.
7/18/07 12:32:54 PM 7/18/07 8:32:54 PM 8:0:0
This is the same session after which my next session till 12:21:49am(19th) wasnt recorded. How likely is it that my session expired exactly after 8hrs.
I dunno if these things are related.
Also i tried to get through MTNL the same way, but it didnt exactly work. But one strange thing i noticed it is. Notice the login and logout times. Notice S.No 11, 12 & 13. The login time of S.No 12 is earlier than the logout time of S.No 11. Also, the login time of S.No 13 is earlier than the logout time of S.No 12.
www.pentagramworld.com/mtnl.JPG
I've posted everything, im trying my best. See if u guys can crack it.
My Friend the session was not recorded because MTNL servers which record data usage were down.This happens many times and nuttin to get excited :|
nothing new..sometimes MTNL servers dont record a session..for reason no1 knows.
overlapping times happen when u reconnect due to crash in which case previous session was alive while u start new session. previous session then times out.
i dont think server goes down. my guess is that the number of simultaneous database connection exceed sometimes and new database INSERTs (exactly when u logout) are simply ignored. so ur session is not recorded
ppl are never happy!comeon think positive, ur session was not recorded and this wud happen many times.
or else .. mtnl prabhadevi will have to arrange for 1 more new gate!
Only if i knew as to when my session wont be recorded....then i would have been happy..:D
How does a computer crash affect the session when u one is in PPPoE mode?
lets say server crashed or database is rejecting connection.. and right at that time u disconnect ur session.. then INSERT command wud obviously fail. so nothing gets recorded! ;)when u r in PPPoE mode and u switch off/on modem right at that time, then same thing will happen
