MTNL 3G Jadoo Experiences and Issues
  • Thread starter Thread starter sanke1
  • Replies Replies 4,394
  • Views Views 464,712
@samrat
What apn are you using?
I am using gprsppsdel for delhi sim and gprsppsmum for mumbai sim. Other apn`s such as pps3g and ppshsdpa doesn`t connects.
Are you using any username pw or proxy in the apn settings, if so, just try using gprsppsmum, leaving everything blank. Strangely for me ppshsdpa works, so does pps3g
I am not using any pw or proxy in the apn settings, just only gprsppsmum. I tried again just now with ppshsdpa and pps3g but no luck. :(
Some people are saying that we need to get hsdpa activated separately to get more than 0.36 mbps download on mumbai sim in delhi. Have you done anything to get it activated or was it pre-activated on mumbai sim?
All my Sims are MTNL Delhi, and BSNL haryana. But afaik, hsdpa is pre activated on all Sims these days. Techinically, if you were getting good speeds in Mumbai, it means hsdpa is activated. You could dig around and get hold of some tech guy in dolphin.
I am from mumbai using 4500 unlimited mtnl 3G jadoo plan. All of a sudden my data network is not available for one of my sims (have switched to mtnl from vodafone for this sim more than a month back and took the 4500 unlimited plan). It was working fine till yesterday morning with good speed, but then it lost the H / 3G signal :( . I tried switching to 2G network but that didn't help. I was travelling all over mumbai yesterday so it's not a network issue. To confirm this I tried a spare sim on my mobile and it worked perfectly fine; but I dont have unlimited plan on this one :(. I complained to the CC but no use, you guyz know how the MTNL CC is. Anyone else facing the same issue since yesterday afternoon?
I just reached Chennai n my mtnl not connecting at all.. do bsnl blocked mtnl? Getting remote server nor responding message.. both in 2g n 3gCan someone confirm? Sent from my HD2 using Tapatalk
Nope bsnl isn't blocking mtnl here, tested by force connecting to bsnl.
Then y I am not able to connect .. previous instances it used to work flawlessly.. hope u using the Mumbai.son only
