MTNL 3G Jadoo Experiences and Issues
  • Thread starter Thread starter sanke1
  • Replies Replies 4,394
  • Views Views 469,189
recently got 'Jadoo' as of 8:40 pm the speed is fluctuating between 100-150kbps .... 1st day 1st hr so wont pass any comments as of now :p
Ha yaar thanks . I was fed up of disconnection issue. Although MTNL cited airport and it's security as reason but I know they gave me " -GOLI" :D
Then I got mtnl broadband and enjoyed 4 months. But then my landlady forced me to take that out. It's a long story why she did so. Hence leave it.
So, now using reliance 3g with Vodafone 3g as backup. :)
Explain this story in offtopic thread ::P
I brought an Sim from MTNL the last week for 3g surfing. The area is yoginagar Borivali west Mumbai. Speed is 2 MBPS. Satisfied as I want it only for surfing and youtube. Slight buffering in you tube but okay. I have an Idea 3g connection too, will disconnect it in a month or two in MTNL works okay. Idea is a racket. The data metering is on the higher side, and they have only post paid plans. I have purchased a prepaid sim, will test the speeds and service thoroughly and post. Modem is Micromax MMX 400R.
How's the micrromax modem thing ? It works fine ? I have this beetel modem slim but has power issues.
@Jitev.singh dude you are awesome 8-10mbps speed is really goodi am getting average 200kbps as download speed from mtnlhow are you able to get this such a good speed?i am using mtnl net connect which supports upto 3.6mbps speed?not using any antenna as supportnot using bsnl network donno how to use thiscan you support your viewswhich method you opt for this great speedthanks
The modem is working absolutely fine. No power issues with mine, the battery works fine if charged, atleast for three hours if you download and surf. This is a guesstimate. You can go in the 3g modem forum and you will find posts on this modem. It cost me Rs.2500 on Naaptol.
I have encountered no problems so far. I stay in Mumbai and my office is at Vile Parle near cooper hospital. The signal strength here is 40 percent and the speed that I get is 1 Mbps. You tube viewing is fine without buffering. So as far as I am concerned no problems with this speed.
@ Jitev.singhWhich modem you are using?m getting 200kbs avg as downloadhow are you able to get this much speed??
