I'm currently using a micromax dongle with a D-Linkrouter and it keeps disconnecting way too much. Not sure if it's micromax's fault or d-link or Mtnl coverage itself. In either case, I was thinking of getting a new dongle just in case it improves performance. Any recs? How about mtnl's own dongle? Is it any good?
i Am using Huawei e1750 1750 its good doesn't heat that much. There are some new models too saw them on flipkart few days back ! and no don't get those mtnl ones, they are expensive too!
I am using the MTNL device for laptop at the moment , but i want to use the connection for my androidtablet also , should i buy a 3rd party 3g & android supported device ?
Can any1 suggest anything between 2k-3k range ? with WIFI as a feature
